Yamaha T25LA tach needed.
  • Yamaha T25LA tach needed.
    Which of the tachometer gauges will work on a 2012 T25LA? The Yamaha website does not list any under T25 accessories. Thanks!
    Most all of them will work,
    6YR-W0035-E2-00 Multifunction Tach Kit
    6YR-W0035-F2-00 Multifunction Tach and Speedo Kit
    If use any of the analog tachs with warning lights or Trim gauge then will also need
    6Y5-83653-00-00 Trim/Oil Harness
    6Y5-83553-N0-00 Instrument harness
      Would that also work with my current model
      T25TLRD? It has fogged up and is very difficult to read. I am sure it is on the slippery slope to failure. That tach says 2005 and above and the T25TLRD is listed as a 2005 engine, but I have also seen 2004 dates for it. 2004 and 2005 are the cut off date so I wanted to be sure I get the correct one. It would be nice if the same tach will work for the old and new when I upgrade later this year. It currently has a digital multifunction tach of the older type with no buttons. Thanks!
        tach for 2004
        i have a aftermarket tach i got at the dealers, been excellent for me. about 50-60 bucks.
        only had to use the next setting other than the one from the directions offered. easy install.
