92- 90 hp yamaha
  • 92- 90 hp yamaha
    Have a 90 hp yamaha was running great then lost power and red oil light came on -returned to dock and shut down -looked to using oil but had just topped off oil prior - restarted later and could not see usual smoke from exhaust - most likely oil pump?
    thanks, steve
    most lilky a faulty tank switch.
    no flow alarms on that engine just oil level.
    no alarms at all associated with the pump.
      oil level switch
      Does the oil level switch low alarm limit RPM?
        yes it does
          thank you, the next day it didnt happen again will check oil flow and repace switch if it returns
