I do have the following problem:
The engine runs fine for around 35 minutes at 4000 RPM. Then it starts to drop in RPM down to about 1500 and immediately comes back to 4000. This behaviour gets worseafter a couple of minutes. Once you throttle back to say 3500 all is fine again - until the same starts at 3500. And so on.
If you try to throttle up to higher RPMs the only effect is that the RPM drops are getting more violent and more frequent.
So you end up limping home with 1500-1900 RPM.
All happens only after ~35 minutes. Leads me to look for a temperature related problem...
I have changed all the fuel lines and cleaned all the filters. The impeller is brand new.
I have no idea where to start, because all the "standard" items like O2 sensor would not be temperature related...
Any help appreciated!
