2004 OX66 200 on Sea Pro
  • 2004 OX66 200 on Sea Pro
    I have a 2005 SV2400, the fuel gauge stopped working, while trying to fix it, something happened. I now have no power to the switch engine or the gauges. When I turn the key switch nothing happens. If I turn the running lights on, I have lights in all the gauges except the fuel gauge. I checked the fuse at the battery, its not blown, I'm stumped. Anyone have any ideas where to start looking. This all after I finally got the water out of the gas and the engine running smooth again.
    Check the fuses on engine.
      They do not appear to be blown. I was working on the fuel gauge, crossed the wires. now the lights on the panel come on for every gauge except the fuel gauge, and no power to the ignition switch or gauges. Stumped
        Should have 12 volts at red wire going to ignition switch and 12 volts on yellow wire when key is on.
          There is a 30amp fuse in the fuse compartment on the 2004 ox66, it looks like the hid it to keep you from finding it. That took care of it, thanks for the help.
