Can you identify this part?
  • Can you identify this part?
    I had the top off of my old 60 HP Yamaha and noticed this part was loose. It is very clean. The wire part has a slight bend in it. Does anyone know what it is? Is it important? How do I reattach it?
    Thanks!
    C. Schmidt
    choke solenoid
      Choke solenoid
      Where does it go? How do i install it?
      Images appreciated.
        Goes in choke solenoid and wire attaches to choke linkage on carb
          what year is your motor ?? need more than old....
            I believe the motor is a 1994-6 or so
            I believe the motor is a 1994-6 or so. I can't find the documentation unfortunately. I plan to go take a look at everything this weekend. i'll gather some information.
            Thanks in advance.
              Plunger for the choke solenoid.
              It goes in the black cylinder shaped solenoid shown here:
                ***. thank you very much! i'll report back/
                  the other end attaches to the carb linkage, center if i remember correctly.....
