2003 sx225 runs great but will stall with the alarm buzzer beep beep beep
sometimes it will restart other times it wont
when it doesn't want to restart the fuel pump doesn't run when you turn the key on. This can happen when it is cold or hot. This did happen infrequently in the past but usually letting the motor cool down would allow you to start back up. now even leaving it overnight is no guarantee that it will start.
so far we replaced the thermostats and poppit valve. removed and cleaned all electrical ground connections. cleaned the vst tank and filter.
I'm afraid to leave the dock as I had to run several miles with my kicker the last time it did this.
does anyone have any ideas?
