Looking for a detail schematic for a twin 4 stroke wiring square command link system Multi Hub 6Y8-81920-01-11.
I was told that a leak in a cooling water speed/pressure sensor caused a ECM short in one engine that knocked the system down.
The installed sensor is the new replaced part from a Yamaha tech bulletin which refers to LIT-18514-00-05 chapter3 which is in a 2008 engine manual.
Unfortunately I have 2006 engines and manual that was repaired before Yamaha released the bulletin.
The engines run fine without the command link gauges working.
Appreciate and thanks for any help.
