trim and tilt 1997 90 hp sensor
  • trim and tilt 1997 90 hp sensor
    How do Itest the trim/tilt sensor on my 90 hp (1997) Yammy? The gauge reponds to the ignition switch and goes to a middle position. If I actuate the trim/tilt lever by the mounting bracket, no change occurs at the gauge. I think that I might have a disconnected wire in the harness. Your help is much appreciated. thanks Bob (pharmsc@aol.com)
    It should have 360-540 ohm's between pink and black wire and 800-1200 ohm's between black and orange wire. Make sure the gauge is for a 3 wire trim sender or it will only read half of trim angle.
