I’ve owned this motor since new and have run it about 50 hours per year. Except for the normal carburetor rebuilds and water pumps it has been trouble free. Well maintained and always winterized. It gets run mostly in fresh water with about 10 trips to the Gulf over its life. Engine was always flushed after my trips to the Gulf.
My problem is an overheating alarm when running over 4000 rpm. After about 2 minutes alarm sounds and rpm drop. Alarm shuts off after about 1 min. If I keep it under 4000 it will not sound the alarm. New water pump assembly – no change. Tell tale is strong. Original Tstats, pressure relief valve and temp sensors. Compression is 122-129. Runs smooth and well. Very minor color change around the top edge of head cover temp sensor hole (just the top lip) on driver’s side top cylinder. This cylinder is the 122 cylinder. Tstats pulled and check – opening before “beef rare”. Just kidding – opening about 150 or a little below. Really heavy calcium or lime buildup up in Tstats water jackets. No salt taste at all.
My guess is pull the heads and exhaust cover and clean out the buildup. I’ve never torn into a 2 cycle engine before, lots of Auto engines but no 2 cycles.
What’s your take, anything else I should check and what should I be careful of?
