1997 90hp yamaha gets on plane,can run 4k-5k rpm, after about 5 minutes starts loosing power and bogs down to about 1k -2k rpm and go to throttle up just bogs, engine will idle like this no problem. Doesnt stall out. Disconnected main fuel tank and fuel line,
installed new 6 gal tank / new fuel line / new fuel filter / new fuel / new plugs and tried to run again and same problem. no alarms / mix oil in fuel,not oil injected.
checked motor,dont see any leaks or anything abnormal. motor does'nt seem
hot,block is actually just warm. Water pump working. Shut motor off, shut batteries off/on - restarted and idoled for 5 min,throttle to wot and planed off and ran a little longer
before bogging down again. Is it going to safe mode.? was planning to replace fuel pump and water temp sensor. would water temp sensor cause it to do this or should i be looking at electronics.
Any advice would be helpfull. Thanks, Mark
