1995 9.9 Yamaha Four Stroke
  • 1995 9.9 Yamaha Four Stroke
    recently bought this motor used and had my local dealer go through it, change oil, etc.
    Currently engine is running hot (water pump seems to be working well and pees a good stream) and leaking oil from around the fuel pump and at a small weep hole (7/64" diameter) that is located below and left of the fuel pump and just above bolt #4, which helps hold the plate on. What is this hole?
    It may also be leaking from an undisclosed location underneath the engine as well. I checked the oil level and it was way up the dipstick, but does not seem to smell like fuel. Could the dealer have overfilled the case?
    any help would be appreciated
    thanks
    Sounds like needs a new fuel pump and water pump and oil change.
