Is there a product I can purchase that I can spray on my engine to prevent corrosion and get rid of salt buildup on my engine under the cowling?
Corrosion prevention
I use WD-40 or similar and a toothbrush to clean and leave an oily protective film on motor parts under the cowling. Spray your tilt/trim rams, motor and pump with white Lithium Grease, sets up a good protective coating on all surfaces to keep saltwater off. Yamaha makes a spray can of "Corrosion Protectant" that I've used, but it's pretty near the same as the grease and costs more$$$....
