2004 115 txr 4 stroke
  • 2004 115 txr 4 stroke
    I am having problems applying power and maintaining power, idle is great, cold starting great, but once on the water there is power hesitaiton and sputtering. I have a friend with a similar motor, with similar problem, he had the VST and high pressure pump screen cleaned to fix a similar problem and I can't find any of these on my engine. Is there a VST on a 2004 115 TXR 4 stroke, Any help would greatly be appreciated.
    If its a four stroke then yes it's fuel injected. What is the model number?
      F115TXRC - I have the parts listing, but do not see a Vapor Seperator tank, All I can see on the parts listing is a low pressure fuel pump, Were is the highpressure pump and VST on this motor?
        It's behind the intake manifold,
        2004 F115TLRC Yamaha Outboard FUEL INJECTION PUMP Diagram and Parts
          how do you get at the VST?
          Is there a trick to getting at the highpressure fuel pump and VST? Do you have to remove the intake manifold?
            You will have to remove intake.
              I have the VST and pump assemble off, any suggestions on fluids to clean, TANK, Screen and pump?
                yamaha combustion chamber cleaner works about the best I have tried.
