My 1997 Yamaha T50TLRV starts fine when cold, but tends to flood when I try to start it after it is hot. I have read on internet forums that a fuel pump diaphragm that has a hole in it could cause this condition. I am considering replacing the fuel pump since it is relatively inexpensive. Is this reasonable?
Hot Start Flooding
Hot Start Flooding
Thanks for the response. When cold starting, I just turn the key (no choke, prime or anything). It usually starts right up. When the engine is hot and I turn if off and let it sit for 15 minutes or so, it wants to flood when I try to start it. I then remove the cowling and spray some ether in the carburetor and then it starts. I think I will try the new fuel pump first. I don't even want to think about going into the carbs.
If your fuel pump has never been replaced then not a bad idea to put a new one on there. If your old one is still O.K. then keep it for a spare.
ÂÂÂÂÂÂÂ
