lighting on Digital multifunction gauge to dim
  • lighting on Digital multifunction gauge to dim
    I have a 2002 year make 225 four stroke Yamaha with two digital gagues.
    The digital Mulfunction tachometer (engine rpm, trim angle, oil pressure, overheat warning, trip hours is working OK.
    The digital multifunction speedometer which diplays (speed, trip distance, time, fuel level, low-fuel, and battery voltage/warning) is not. It appers
    that the readings are beig displayed but the lighting is not bright enough to see the display without shading the display and looking very close at the gauge.
    Is there a way to brighten the information be displayed.
    Thanks for your segggestions
    Mike
    No there is no adjustment for brightness.
      Backlighting adjustment
      Download the multifunction guage manuel... It shows you how to adjust back lighting....
        Can't find the manuals....do you have a link?
          Yhere is no adjustment on the Multifunction gauges, only the Command Link gauges have that option on 2006 and newer motors with Command Link.
          Operation_Manual_Square.pdf
          Operation_manual_Round.pdf
