hi all. my 05 f100 fuel inj has a hunt at idle and is very hard to start cold. black soot comes out exhaust which cant be good. ok so put comp over it all in spec iac,tps,new filters,vst clean 160 each cylinder,new plugs,new gas,inj flowed and checked,thermo sensor new,air flow metre also new. so after i get the girl going warmed up about 5mins slight hunt. if i pull the scavenger hose that goes to the air box off hunt stops idles beautiful. no fuel in oil . smell of fuel coming out when i take tube off when running. im running out of hair maybe some one will know what im dealing with before im bald. cheers and thanks in advance. rodbolt?
f100 hunting idle hard to start cold
Did you check air silencer for blockage or is hose being pinched closed with install back into silencer?
yip everythhing clear and unobstructed. when it is hunting at idle i took the vacume hose off vst and sat at 1000 rpm smooth. it is like the fuel air mix is not right. iac,tps,therm sensor sort the comp for idle. comp doesnt like something to keep adjusting idle. i think im looking for something small? sorry for the delay in responding i live in nz cheers
dunno
last of the F100 in the US market was about 2002 and was carbed.
we never got the F100EFI motors.
black soot would indicate its rich.
could be a VST venting issue, ISC valve?? can be tested but typically a failure is rare other than mechanically stuck.
