200 HPDI 10 hour
  • 200 HPDI 10 hour
    Under the advice of my Yamaha Dealer, I did not have the 10 Hr check Done on MY 04 200 hpdi. I did, however, check the plugs, change the gear oil, and grease the fittings. Is there any other procedures I should follow....such as an oil adjustment?? Thanks
    Jake Allegrini
    Just check the fuel filter and that the oil pump linkage is against the stop at idle. The ECU handles the oil enrichment during breakin via the electric oil pump, so there shouldn't be any linkage adjustment necessary on the mechanical oil pump linkage. The HPDI motors are the only ones with the additional electric oil pump.
    Mike ......... Miami, FL
