Odd run 85hp yamaha
  • Odd run 85hp yamaha
    Took my boat out today, it ran great untill late this afternoon. All of a sudden it started bogging down I pulled the throttle back, and then tried to give it the gas and it just bogged and only got up to 2500 rpm's, tried several times same thing. So I put it in neutral and fast idle and rev'd the motor up to 5500 rpm's then put it in reverse and gave it the throttle and it rev'd up and worked perfect. I thought power pack or coil till I rev'd it in neutral and reverse gear. Then thought a linkage broke that advances the timing but it's fine...Has anyone else experienced this and how to fix?
    sounds like a fuel issue
      Boat ran great all day say 5 hours before problem, and why would it rev up to spec in neutral and reverse?
        You should never rev a motor in neutral, fast idle is all.
        your motor can run away and come apart by reving it like that
        Without a load not much fuel is needed and reverse does not load the motor like forward
        But would be a good idea to check timing and everything else again to make sure
          are we thinking fuel pump issue?
