Hey guys,
I've had this motor for the last year, and the tilt has been annoying me since day one! Basically it doesn't go all the way up! So I can't put it on the tilt supports in the fully raised position. The cylinder itself works mint, have replaced and bled all the fluid. My guess is the previous owner has changed the tilt cylinder with another model.
I'm struggling to find any information on the amount of travel the cylinder should have, or any part numbers etc. The cylinder itself is blank, but the whole trim/tilt unit has "61A-25" and under that "7G-*272" (I can't see what the * is anymore)
If someone has a ox66 225/250hp, can you please measure the tilt cylinder body? And possibly the tilt shaft length fully extended?
And has anyone got any suggestions or ideas?
I'm drawing a blank, short of buying a whole second hand trim/tilt unit. Which over here in NZ aint cheap! (especially when mine is working great otherwise)
Jared
Jared
