Hopefully someone is familar with this. Oil pump was leaking and found the shaft at the bottom of the pump that attaches to the throttle linkage came out and it appears that a piece broke off the end allowing it to slip by a retaining pin that is in the casting of the pump.
I do not see as separate part number for the shaft only, only a complete pump assembly. Any body know anything about this?
Thanks!
Thanks!
