Yamah c90 broken water pipe
  • Yamah c90 broken water pipe
    Is there a way to repair a broken water pipe without pulling the powerhead? I was thinking of buying the part and doing a splice with a sleeve made from braided hose?
    Thoughts?? thanks
    Powerhead is not that hard to remove on a 90hp, I would replace it.
      Thanks. It's just the boat is on a lift and very difficult to get to from the top. I stand in the water at low tide to remove the lower unit and can work on lower section very easily.
      But you're the expert.
      Thanks..
        You will need a hoist to remove engine, it's a little heavy.
