i have a 2010 90hp four stroke that the big ground wire on the motor from the battery came loose i found that the ground on the side of the motor was loose and had been arcing for while causing the bolt to heat up when i went to tighten it up the bolt broke off in the motor i took it too my local dealer they told me to relocate it to a bolt on the starter which i did and it worked fine the reason they did not want to fool with the removel of the bolt was because its aluminum they did not want to mess things up my question is does anyone think this will be a problem in the future
