im having an issue with water leaking out of the ypvs on the shaft towards the front of the craft i have the service manual and it says that it needs an oil seal and washer and circlip im not sure if that will stop the water coming in or is there a missing hose where this connects to. the diagram is located on cylinder crank case 2 diagram
2000 yamaha waverunner 1200 limited
There is no water that goes to power valves, water would have to be coming from somewhere else, water passage on head or exhaust.
Is it like number 12 in this diagram? 2000 XL1200 LTD - XA1200Y Yamaha Waverunner EXHAUST 1 Diagram and Parts
its not cracked i seeing the water coming out of the end when i run on the house i tried pulling the exhaust yesterday but i need some sockets that swivel cuz its so tight in there i think it maybe was plugged with something by the previous owner idk cuz it run and rides fun no cooling issues it just fills up with water then it bogs out
ÂÂÂÂ
