Heads up. I have just purchased this boat so I have no real history of the boat other than the obvious. The boat is being kept temporarily on a dock so in order to keep the leg out of the water, I have tilted my pair of F225's to max (all the way up). The boat normally stands in dry stack or trailer so I had not tilted it all they way up before. Today when I went to check on the boat in the dock, I noticed engine oil in the transom of my Wellcraft 270 Coastal
On inspection, the oil was leaking out of the cowling where the cables enters the engine via the thick black protective hose. I traced it back further to the engine oil dipstick. Now I'm not sure if the dipstick had been pushed all the way home by whomever checked the oil last. The level is now just under half way between the Hi and Lo mark. Upon inspecting the Stbd engine I noticed that the oil is closer to the Hi (full mark) so I'm assuming who ever topped up the oil made sure they filled it pretty well. Is this "normal" or should I say "happened to anyone else"? These motors do seem to tilt high leaving the engine block sitting at a pretty steep angle
