Been reading this forum for some time and decided to post - this issues appears several times, but no where has the actual problem been found - or at least shared.
1995 2 Stroke, 90HP, TLRT
Runs great in Bypass Mode, two yellow wires on CDI box disconnected - when hooked up - motor fires but does not stay running.
Bypass Mode - runs on Cylinders 1 and 3. The box says this is a timing issue.
What has been replaced so far by two different dealers are: New CDI Box, Pulsor, Stator, Charge, Crank, Rectifier - the only think remaining is the Flywheel.
THis is not an electrical problem, harnesses has been isolated and still have the same problem.
When in Bypass mode there is no spark going to Cylinder 2 - this is normal and should be.
Compression/Fuel Good - but engine runs great in bypass mode.
Sometimes I can disconnect the crankposition sender and the engine will also run on 1 and 3.
Can this timing issue be caused by weak mags in the flywheel?
Any help would be great - also every wire has been traced out, and goes where it should, and not shorted to ground.
Thanks so much....
Thanks so much....
