15 hp grease fittings
  • 15 hp grease fittings
    Does anyone know where the grease fittings are on a 1996 yamaha 15 hp outboard?
    Should be about 3 zerk fittings, one on the pivot shaft(may need to tilt motor up for access), and a couple on the front of the tilt tube, usually under small black rubber caps to protect them. Pry off caps for greasing, then replace. Grease your cowl latches, throttle slide/mechanism, gear shift linkage, etc., while you're at it. good Luck!
