I guess if the pressure in the bowl is increased. it would force some fuel up into the venturi area via the main metering jet, but isnt the bowl vented to atmosphere?
yes its vented.
however its a calibrated vent.
air pressure at about 14.7PSI is on the bowl.
the intake pressure (vacum) is much lower.
add a touch more pressureon the liquid in the bowl and the fuel mix becomes richer.
