I have a 2002 115hp 4-stroke that has never been repaired. The engine was running fine for about 45 min then made terrible noise grinding and stopped. Had a certified Yamaha repair stator and broken crank key. Put in water and ran fine for 10 min then started making noise, little vibration. I stopped it and found the bolt on crank was getting loose. The tech swears he torqed bolt down to specs.. Any ideas what could make bolt get loose when tight??
115hp flywheel loose
