Hi boat people, due to zero compression on cylinder one I looked at the piston which indicates a particle went through damaging it, possible ring issue?? carb looks fine, sleeve isn't bad either ... next step I guess will be to remove the block. What is the procedure? Can the engine remain on the boat or do I need to separate it from the transum in order to be able to pull the block and piston?
I appreciate your help! stay dry!
mischa
I have a 1986 70hp yamaha 2stroke 6H300
mischa
