Has anyone pressure tested a lower unit? I have a 80hp 4 stroke and the spec's call for a pressure of 14.2lbs for 10 seconds. I pump up to 14lbs and unit drops down to 12 lbs in 10 seconds. I assume that a drop is to be expected, but how long before the pressure drops. Is this 2lb drop ok? Should it hold 14.2 lbs for 1 hour? I hate to ruin the lower unit. I did replace the water pump and lower seals. No evidence of water in lower unit oil. What do think....
Thanks Geowhizz55
Thanks Geowhizz55
