2001 ox66 200 is being worked on now slowly..
was told so far the fuel pump has a bad diaprham and low compression in one cylinder which possibly could be do to a bad head gasket? the gasket has never been changed.
weird thing is the motor seems to run fine except for a little shake at idle.tops out at 5400 rpm like normal.
heard a tapping noise last trip out which i never heard before which is why i took it the shop. i did clean the o2 sensor like all the directions say before that trip which was the first of the season.
