1995 twin carb 225's yamaha guage cluster wiring?
  • 1995 twin carb 225's yamaha guage cluster wiring?
    Hello all, I am new to the forum and have searched for Guage cluster wiring information. I have purchased a 1995 century 3000 center console and I am looking for the guage cluster wiring diagram. I have twin tach's, FMC and multi function guages. They where all replaced before I purchased the vessel and the back light stays on when the keys are off, I also have a battery drain issue I am working thru. 3 Batteries with 2 perko 1,2,all,off switrches and 1 on/off switch. I installed 3 new batteries to start from a good voltage source, and now I am proceeding to find my "issues".
    Thanks in advance for any diagrams that would be helpful.
    south Florida,
    dbalding@floridawings.com
    the gauge lights should be powered with your running lights,not key
    the seperate blu/blks on gauges are the light wires
    for the drain just unhook one accy at a time with meter inbetween
      the memory circuits in the speedo and FMM will drain anytime the battery switch is on.
      the dark blue wires at the guages are hooked up to a power source.
      find it and either take them to a key on yellow 12v source or take them to your running light switch.
      dark blue on the gauge is for light.
        THANKS!!!
        I will do it today. I am hoping to launch in the morning for some maintenance trials then family run on the weekend.
        DB
          Thanks, Everything works as advertized and lights come on with nav lights.
          you guys are the best,
          Thanks again.
          now, its time to do some sea trials...
          Sea Scout Run...
