What is the correct RPM
  • What is the correct RPM
    On a 2005 Yamaha 2 stroke 50 HP what is the correct RMP on netrual? I was having proble with miss fire and I star playin with the C.D.I. UNIT and fix it but now my RPM are 1100 that is the best I can get it withou miss fire. before were on 800 RPM.
    what seems to be the trouble?
    are you loosing spark to one or more plugs?
    Or is it running too lean and has a lean sneeze?
    You should not have to do anything with the CDI for miss fire.
    What did you adjust? the wiper that helps control the timing at idle and WOT?
