Sometimes the motor won't accelerate past 3,000 Rpm at full throttle. Then for no reason the motor starts running good and will accelerate to 5700 RPM. Anyone experience this before?
98 T50 TLRW with intermittent problem at top end.
Originally posted by Captkirk View PostSometimes the motor won't accelerate past 3,000 Rpm at full throttle. Then for no reason the motor starts running good and will accelerate to 5700 RPM. Anyone experience this before?
Rod is on a roll tonight so watch out.
Guys testing things is the best way , but you have to test when the problem is there.
Rod what is that testing thingy called? a ******der
back to the present time,
testing is a must to identify if it is fuel, timing, or spark that is wondering off from what it is suppose to be
