I have a 40 HP outboard, the amount it pees out the end is as cold as the water going in also the flow would make you think its a jet boat, but it is overheating. Anyone have any thoughts.
Overheating
Originally posted by robertlawson View PostI have a 40 HP outboard, the amount it pees out the end is as cold as the water going in also the flow would make you think its a jet boat, but it is overheating. Anyone have any thoughts.
Tell tail comes out before running through motor that is why it is not hot.
Might want to test thermo switches and stat to make sure they are operating in spec
and measure temp on head to make sure it is overheating.
How are you sure it is overheating?Last edited by 99yam40; 05-14-2012, 05:04 PM.
