Yamaha 90 2 stroke motor 2002 won't start
  • Yamaha 90 2 stroke motor 2002 won't start
    I have a 2002 Yamaha 90 2 stroke motor. Last weekend I was waiting to put my boat on the trailer. I turned off the motor and when I went to start it nothing! I had to pull start it. I have checked the following. One side of the relay has power. If I jump acroos the relay the engine cranks. I have check the continuity of the kill switch. And there is 12 volts constant after the fuse on the red wire that goes to the left side of the starter coil. I did not check the brown wire. What should I do?/?
    Oh by the way!! I was having problems w/ my trim gauge prior to the motor not starting.
      There are 2 neutral safety switch's, one in control box and one on shift linkage on engine, check the one on engine first, disconnect the brown wires from switch and connect wires togather if engine starts the switch is bad,test the one in control box the same way.
        thanks
        i bypassed the linkage sensor and went fishing!!
