I replaced my water pump impeller and the job seemed to go just fine. I have done this before on MerCruiser Stern Drives and Evinrude outboards. This was my first Yamaha. I put her in the water and she started right up but would not shift to any gear. I pulled the hood and saw that the shifting mechanism was working OK from the cable to the slider mechanism and everything looked good upstairs. Is it possible that I missed something when I pulled the lower unit and put it back on? The lower unit went on just fine so I assumed that the shift shaft engaged OK. (It shifted OK before I pulled the lower unit and replaced the impeller.)
Thanks for any help,
Capt Brian
Capt Brian
