when accelerating engine cuts out around 3000 rpm for a split second and then continues accelerating. Sometimes it does it a couple times. Ussually straight off the trailer the first time it is normal. top end is good and idle is fine any ideas? Local dealer is having trouble diagnosing, no codes filters all replaced. Any ideas would be greatly appreciated...
05 hpdi 225
tests
they checked for codes, changed fuel filter on top and checked fuel pump, no joy. ran again today, half the time it cuts out and then picks right up and goes like hell. the other half it jumps on top and goes like new. they have no idea what it is, cant simulate in tank only under load
So they did not test/monitor fuel pressures and vacuum like the last post suggested, the just replaced a filter.
Maybe it would be a good idea to do the things suggested
roger that. i will talk to them and see if they can, may have to take it to a better shop! thanks for pointing me in a direction, let you know what is found. been battling these guys for 2 months now
skeeter did you ever figure out what the problem was with your hpdi? i am currently having the same issue with my 05 250 vmax. i would love to have some good info from someone that has already dealt with this issue
found it!!!
turns out the filter inside the vst tank was way clogged and the 4 conical shaped filters on the high psi pumps were the same. Ethanol sux!!! Changed and cleaned all and runs like a raped ape!
ÂÂÂÂÂÂ
