I would like to disconnect my oil injection system,the pump has become unreliable. I'm mixing 50/1 ratio in the gas tank. Do I need to completely remove metering pump,if so how do I cover hole that has gear that drives the pump? Is there a kit made for this? Does the carb need adjusted after this change?
1987 50 hp PRO LH
