Motor started smoking badly due to main tank over filling and pushing mostly into the engine. removed the oil level gauge to test at the lake and noted that:
1. when was at float at top pump in sub tank stopped
2. when the float was in the middle pump in sub tank would start
3. when float was at the bottom red light and buzzer came on and would not go off until key switched off then back on and float moved towards top
4.the brass like shaft had some rough spots on it about 1/3 of the way down from top
The same smoking and bad running continued due to the main tank over filling after I put it back together.
When I got home I cleaned the rough spots up with some wet/dry 600 grit sand paper. Now the pump will not shut off and the red light and buzzer will go on and off intermittently as I manually move the float on the shaft.
I am not sure of the actual year model of this engine, serial number is 6E5L352105, is the correct replacement part 6E5-85730-10-00?
