Convert Tiller to remote 1999 25 hp
  • Convert Tiller to remote 1999 25 hp
    I searched the forums for my particular situation before posting, but couldn't find the exact part numbers.
    Pull start, Manual tilt, 1999 25 HP Yamaha 25MLHX
    Want to add a center console and convert from Tiller to remote steer. I have found the steering assembly I will use, but need throttle/shifter and the rest of the parts to make everything fit to the motor.
    I will keep it as a pull start, just need to have a throttle, shifter and steering wheel on the console.
    Is this the correct part number ?
    6J8-48511-51-4D
    I am sure I am missing something ...
    Thanks for your help.
    Would need
    6L2-48501-11-00 Remote conversion kit
    701-48101-51-00 701 Side mount Control box
    Also need two MAR-CABLE-xx-SC(replace xx with length cable needed) control cables.
      Thanks for the reply.
      When I search, I keep coming up with this
      1999 F25MLHX Yamaha Outboard REMOTE CONTROL ATTACHMENT MH EH Diagram and Parts
      The conversion part you list doesn't look like it fits the '99 model. Being such a big bag of parts, I would hate to order it, tear it all apart and pull (whats left of) my hair out trying to figure out why I can't make it work!
      The control box looks good, but I can't get the cables to come up, even when I substitute numbers for the "xx" like 08, 12, 10 whatever. Can't find the cables.
        You listed model 25MLHX which is a 2 stroke model not a F25 four stroke model.
          That is exactly why I ask, because I know I'll buy the wrong part.
          Ok, if you say that will fit the '99, then I'll go with it.
          Now, the cables. I cant get the cables to come up on a search. say ... a 10' cable for example.
          MAR-CABLE-10-SC or any number I put in there will not show up on a search.
            Yes the part numbers I listed are for your motor.
            Here is cables MAR-CABLE-10-SC
              Great!
              It's strange that when I type that exact part number in the search, I get nothing? It won't recognize that part in any length.
              One more time. If I could do it on my own, I would, but the search won't work. After reading the description, I see I need a a 12' length. If you could please show me a link to that cable in 12' my cart will be complete ... for now.
              Thanks again.
                MAR-CABLE-12-SC 12FT Cable
                You can use the Multiple Part Search tab on left side, works good. Boats.net - New and Used Boats for Sale, Outboard Boat Motors, and Discount Outboard Boat Parts
                  Oh, I see! It does work well!
                    Ok, got all the parts ordered. Console, Steering, conversion, etc. Lets see how it all fits together.
                    For those interested in doing this project, with an inexpensive console ($200-$300), you are still in the neighborhood of $900-$1000 to add a center console to your tiller drive boat.
                    But they look so cool! Plus, storage in the cc for battery, fire extinguisher ... whatever you want.
                    And they look cool!
                    Thanks again for your assistance with finding the parts.
                      Have not received the parts yet, I think some were backordered. I can already tell I am missing one part. The rod that goes from the steering hook to the steering cable ram.
                        65W-61350-00-00
                        This is all I could find, but looks like F25MLHX. Will this one fit?
                        Seem to have a lot of trouble finding 25MLHX parts. Always wants to substitute the 4 stroke "F" model.
                          Received the throttle lever assembly, but it is set up as a Starboard gunwale mount with cable coming out the aft side. That won't work on a center console.
                          Do you carry a true sidemount center console contol?
                            Yes 701-48102-51-00 mounts on opposite side than one you got.
                              Ok, thanks,
                              I still cant figure out the one missing piece. The steering cable runs through the tilt tube. but I have nothing to attach it to the motor.
                              What part goes from the steering cable to the engine hook?
