I have a 94 Yamaha 250. I just replaced the thermostats, water pump ass'y, flushed everything, and am alarming after running in the driveway for 5 minutes (was alarming before I changed everything out and the old impellor looked healthy). I checked temps and the heads by the spark plugs are 198 degrees and lessen as you check the lower head temps. the thermostat housing is reading 200-205. What temp do the thermostats open at and what temp should the heads read using a temp gun??
Also, Since the gage thinks I have no gas, does Yamaha set off an alarm for no fuel? The alarm is constant; no beeps.
