Still waiting for advice why my z200 HPDI does not power up over 3700rpm?????
What happened
Is there a reason you do not monitor fuel pressures like most recommend to see what is going on?
Probably need the software and cord to hook to laptop, but it is the best way to troubleshoot these HPDIs
the high pressure pump can be monitored with a multi meter and a service manual. the medium pressure can be monitored with a standard fuel pressure test guage that can read 70 psi minimum.
BOTH pressures should be monitored simultaneously at the problem RPM and load.
ÂÂÂÂÂÂÂÂÂÂ
