I have an '01 200 TLRZ that smokes on start up and builds up carbon. Is there a plug to use that will help with both of those problems? Also, Boats.net parts page list a certain plug and directs the user to a tech exch #0 2000-15A but I can't find that on a Google search......any suggestions? Thank you!
2001 200HPDI spark plug recomendations
Need to get your dealer to check the serial number to see if any updates are needed to be done on it.
Since I know the serial number is there a way I can access service bulletins for my motor or does a dealer have to do it?
there were some running changes and dealer installed updates about that model range.
if the ign coil primary connectors are black it uses the single electrode plug, if gray use the duel electrode plug.
You can post the serial and we can can check it for you but we can't see the motor to see if updates have actually been done.
My motor is a Z200TLRZ and the s/n is 150605 with a mgf date of 06/2000
Thank you and I look forward to seeing the updates.
Run that serial and it does not need any updates and there was no warranty claims ever filed on it.
Z200TL serial number 150689 and under uses BKR7ES-10 Spark plug.
Originally posted by boats.net View PostRun that serial and it does not need any updates and there was no warranty claims ever filed on it.
Thanks again
ÂÂÂÂÂÂÂÂÂÂ
