Last week I had the water pump replaced and carbs. overhauled on my 2004 40hp 2 stroke yamaha outboard by my local yamaha dealer. I took the boat out saturday and it ran great. However i did notice that with the trans in neutral that the throttle would not move at all. I also noticed when I got the boat back on the trailer that there was a lot of water draining out of the lower unit between the housing and the prop. I took the boat back to the dealer today and was told both of these conditions are normal but to leave it with them and they would take a look at it. Now i know that before the throttle would move with the unit in neutral and I know that I never noticed water draining from the lower unit before. The water that was draining was clean heated water, I didn't see any oil in it. Is the dealer right and this was just the water draining from the engine or is this a problem.
Double checking
