2002 80FTLRA flush leaking
  • 2002 80FTLRA flush leaking
    When running at speed a lot of water leaks from the fresh water flush screw connection. It seems to have a lot of pressure have not replaced the gasket. When attached to a hose for flushing it does not leak. Motor does not over heat but did not run very long after I saw the leak. Thermostat tested ok. Just the gasket or something else?
    Look at it and see if gasket is bad or it's cracked or damaged.
      It's only a garden hose gasket.
      Stanley Islander 19, 2006 Yamaha F150TLRC. Ottawa, Canada
      16' York River, 1986 Yamaha PRO 50.
