How tough of a job is it? Any special tools required?? Suggestions?
C60 trim motor replacement
If it's been in saltwater bolts may break, back bolts are hard to get to.
Not sure about the C60 , but on my C40 I pulled the top pin with motor locked in up position and tilted T&T unit out away from transom far enough to get to the back bolt.
The foam filter fell apart when I removed it, had to do some clean up and wait for part to come in. They did not keep the filer in stock at the local Yamaha shopLast edited by 99yam40; 04-10-2012, 12:39 PM.
Â
