1994, Yamaha 2 stroke 70 HP 70TRLS.
I am original owner working 100% from 1994 until 2011.
Last Fall the Trim Up started to "act up" on several occasions I had to go all the way down and then it would go up. Again this Spring worked most the time and NOW NO TRIM UP. My Lund Pro-V has 2 Trim Switches and 1 on Motor.
All 3 Trim switches acted exactly the same (so I eliminated them as the problem).
When trimmed Down I hear relay click then Trim Motor Run.
When trimmed Up I hear relay click then No Sound from Trim Motor.
I removed the UP & Down Wires that cam out of Trim Motor (Blue & Green) from the Relay, then as I read here connected them to a good 12 vdc Battery and then reversed the Polarity and the Trim Motor WORKS UP & DOWN as normal.
Further reading here (post about Big Spark Little Sparks Ect) well I can say "Sparks are very subjective IMHO.
I do have a Fluke Voltmeter for Testing.
After all above testing my Theory is the Relay finally went Bad, but Would like to use Voltmeter to confirm before $115.00+s&h
Part Number is 61A-81950-00-00
TY in Advanced
TY in Advanced
