First time I changed the foot oil.
I drained it all and started pumping in new.
When it appeared to be full (oil coming out of the top), I put the screw in during a slow pump and had it seep out around the threads and I tightened the screw.
Well, I wanted to see what would happen, so with the screw tight, I gave another pump...and another...
The question is -- should I pump more in with the top screw tight? I guess this would have the fluid under slight pressure?
Or, do I simply put the screw in when the top is draining oil and be done with it?
Thanks for a prompt reply!
