Flushing Yamaha F200
  • Flushing Yamaha F200
    What do you recommend is the proper way to effectively flush a Yamaha F200 Outboard? Thanks...
    Connect hose to fresh water flush adapter and flush for about 10 minutes.
      Can you run the engine on fresh water flush adaptor??
        Yamaha owners manual says no
          however we do, it typically works better than rabbit ears.
            So the answer is its ok?? Yes it seems better then ears!!
              I would think both would be best if running motor
                yes, we start everything from the f150 to the f350 on the hose flusher.
                works better han the rabbit ears.
                if we need to flush more than about 5 min we use both the hose and the rabbit ears.
